Nitrogen Volume Calculations Including The Compressibility Factor, Z
#1 ab231
ab231
Posted 26 June 2011 - 05:09 AM
I know from engineering tables that at 10,000 psi and 200 deg.F for example, 1,985 SCF of Nitrogen occupies 5.6146 cu.ft of space (this assumes Z=1). Can someone please advise a formula to correct this volume, which includes the compressibility factor, Z.
#2 acer_asd
acer_asd
  • 28 posts
Posted 26 June 2011 - 10:47 PM
Have you considered using equation of state for calculating volume?
In my opinion you can use Peng Robinson equation of state.
you can use following file
www.egr.msu.edu/~lira/computer/EXCEL/PREOS.XLS
Hope this answers your query
have a nice day
#3 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 26 June 2011 - 11:06 PM
You can look at http://www.cheresour...h__1#entry42680 as a guide of compressibility factor estimate. Nitrogen critical conditions are needed in advance, which can be easily found.
Another example of a gas volume calculation based on compressibility factor is at http://www.cheresour...h__1#entry36507.
Hope above is helpful. It may be easier to use a simulator to calculate N2 volume, using e.g. Peng Robinson equation as suggested in the post by acer_asd.
#4 breizh
  • 6,940 posts
Posted 26 June 2011 - 11:50 PM
Hope this helps
#5 breizh
  • 6,940 posts
Posted 26 June 2011 - 11:52 PM
Attached document.
