Software List For Commissioning & Pre-Commissioning Of A Plant
Started by rahul yadav, Jun 27 2011 03:31 AM
Posted 27 June 2011 - 03:31 AM
Dear Sir / Madam,
i a commissioning engg. - Projects, preparing plan of a plant pre-commissioning & commissioning procedure (all DOC required). i want to some software for this.
thanks,
Rahul
thanks,
Rahul
Posted 01 July 2011 - 02:42 AM
Hi Rahul,
Why not develop the commission procedure(s) in MS Project? You can detail every step involved, set resources, give each activity a time, set its predecessors and successors and develop bar charts of the commissioning program plant item by plant item and also for the entire project.
Best regards,
LRS
Best regards,
LRS
Dear Sir / Madam,
thanks,
Rahul
Posted 29 August 2011 - 01:53 AM
SIR,
Can you guide, how hydrocaban line inertize (with N2 or steam) and leak test of that line. if i am using steam for leak test. can i inertize line immeidate after leak test (with steam).
thanks,
Rahul
thanks,
Rahul
Posted 30 August 2011 - 05:29 AM
Hai,
The line is subject to leak test by admitting air (pneumatic test which is 1.25 times of the design pressure.
Then the air is to bereplaced with Nitrogen. The line is completely depressurised, pressurised with Nitrogen to about 0.3 to 0.5 bar and as many vents as possible to be opened to bring down the Oxygen content to less than 3%. Once after achieving this target figure, the line is to be purged at single point vent by keeping positive and continuous flow of Nitrogen to reach 0.1 % which is acceptable to admit hydrocarbon.
Normally 3 to 5 times of line volume is required to successfully inertise the hydrocarbon line.Whether to inertise the line with steam depends on process requirement.
Posted 16 November 2011 - 11:42 PM
check this out http://www.cms-sg.com .
I think they can help you with that. just give them a line.
cheers,
cheers,
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
