Fcc Slide Valve
Posted 11 July 2011 - 02:23 PM
The FCC slide valve is not functioning properly in our unit. When given a signal from DCS, it opens or closes in strokes (not smoothly). The slide valve actuator is powered by air. In the last shut down, we checked the interior of the valve and could not find any mechanical problems. We decided to put a oil box from which the air passes by to regulate the actuator. This was a move to lubricate the actuator so that it can function smoothly (Not mentioned in the Operators Manual). Now the valve is responding very slowly. When given an opening of 50% manually from DCS, it goes till 90% and then starts to close. I've some doubts regarding the operation of this slide valve:
1. The catalyst is circulating at nearly 400°C and 1 barg pressure. Is it possible that if the catalyst is wet, it can cause the slide valve to function irregularly (I doubt that the catalyst can be wet at this temperature, the water is produced in the reaction)
2. Is putting the oil box has actually caused the actuator to function more discontinuously ?
3. What was causing the problem before ? (No mechanical difficulties, actuator power sufficient)
Also, the delta P across the valve is significantly low causing poor catalyst circulation.
Any suggestions ?
Thank You
Posted 12 July 2011 - 02:27 PM
Any suggestions ?
Thank You
Your temp is not enough ( Reactor temp at-least 5300C and re-generator 7000C). More over check your servo valve. your problem looks more with servo valve.
check it and coming back again for further discussion.
Toor
Posted 13 July 2011 - 01:15 PM
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
