I have to design a decanter centrifuge to dewater the sludge which is get from the clarifier.
The waste water is contains spent grain and it is treated by both anaerobic and aerobic digestion.
I want to know the design procedure of the decanter.
thanks
Help Need To Design A Decanter Centrifuge
Started by Uddhi, Jul 23 2011 11:03 AM
Posted 23 July 2011 - 11:03 AM
Posted 23 July 2011 - 08:24 PM
Let you try this resource ,you will find the methodology . Books like Perry should support your query
http://www.filtratio...edimentcont.asp
Hope this helps
Hope this helps
Posted 23 July 2011 - 11:28 PM
Hi
Perry's handbook has a section on centrifuges, You may also try websites of centrifuge manufacturers for clarification(alfa laval, broadbent, andritz)
Posted 24 July 2011 - 12:13 AM
Hi
Posted 24 July 2011 - 12:18 AM
thank you all. I'll go through with them
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
Optimal Settings And Clogging Prevention For Gnlw224E Decanter CentrifStarted by Guest_Lev1231_* , 02 Feb 2025 |
