Hydrocarbons In Glycol Flash Tank
Posted 25 July 2011 - 05:43 PM
What are the main reasons of seeing lots of Hydrocarbons in Glycol Flash Tank in Dehydration Projects?
Thanks,
Posted 25 July 2011 - 10:07 PM
Thanks,
The biggest reason this is probably happening is that the hydrocarbon dewpoint of the gas is higher than the glycol supply temperature. Easiest way to tell if this is true is whether the inlet gas (which is probably coming from a gas/liquid separator) is warmer than the lean glycol. Should be at least 10°C colder.
The second possible reason is if your gas contains significant aromatic species (BTEX), which are soluble in glycol. These however tend not to separate in the flash drum but are found in the still overhead vapours (which is bad from an environmental point of view).
Posted 25 July 2011 - 10:14 PM
Carry-over can be prevented by maintaining proper levels in the inlet separator and by keeping mist mats clean. Condensation in the contactor can be prevented by maintaining the inlet glycol temperature about 3 °C to 6 °C above the inlet gas temperature.
Posted 25 July 2011 - 11:06 PM
If the gas contains significant aromatic species (BTEX), then what should I do to solve this problem?
Thanks,
Posted 25 July 2011 - 11:57 PM
U need to check the outlet gas temperature from contactor. this should be lower than inlet glycol temperature to avoid hydrocarbon condensation in contactor bottom. hope this will solve your problem.
Posted 26 July 2011 - 10:42 PM
Glycol temperature is almost 10'F higher than the inlet gas temperature, so condensation probably does not happen. I am not sure about the carryover in inlet gas, as the plant inlet flow rate has changed. Is it possible that the separator may nor be adequate for new flow?
Thanks,
I did work in a plant many years ago where carryover from an upstream separator was the cause of many problems in both amine and glycol systems. You should check the separator and potentially place a coalescing filter in the gas stream to capture any entrained droplets (if if appears the separator is undersized).
For BTEX, the solution is to either remove it from the gas upstream, remove it from the glycol via carbon bed (although this is expensive to operate), or incinerate the glycol regenerator vapour. You may also need to run the glycol regen hotter to ensure you strip the BTEX out. A company that has expertise in this field in Process Ecology in Canada (http://processecolog....php?r=services) (I do not work for them)
![]() Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
![]() Free Vent For Api 650 Tank - Bug Screen / Bird Screen RequirementStarted by Guest_Cabbarbeybaba_* , 03 Jul 2025 |
