Can anyone pls explain how to calculate velocity in the discharge piping from relief valves and blowdown valves feeding the flare header?
Kunal
Relief Valve
Started by Kunal_DNV, Aug 05 2011 09:25 AM
Posted 05 August 2011 - 09:25 AM
Posted 06 August 2011 - 06:01 PM
Same way than in other lines: by dividing volumetric flowrate by cross-sectionnal area (using internal diameter).Hi,
Kunal
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
Storage Tank Relief LoadStarted by Guest_hum464_* , 10 Sep 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
