Hi
I am looking for the equilibrium curve/data for the solubility of Hydrochloric acid in water. I have a Syngas which has ~100 ppm of HCl acid which is to be removed by an water wash by scrubbing. The limiting concentration of HCl in water is <1800 ppm of water; I am using Demineralised Water for Scrubbing.
Nilanjan
Absorption Of Hcl In Water
Started by nmaitra02, Aug 10 2011 05:23 AM
Posted 10 August 2011 - 05:23 AM
Posted 10 August 2011 - 06:21 AM
You should use the search button , top right ! Annyway I've attached some data to support your query.
Posted 12 August 2011 - 10:50 AM
Thanks a lot, it helps!
Nilanjan
Nilanjan
Posted 17 February 2012 - 07:40 AM
Hi i am struggling to design hcl scrubber. I ve got hcl gas comming in from gas liquid seperator and make up water coming in from a tank so that i can produce 36% conc hcl acid. Can any1 help me suggest any books or methods to carry out step by step calculation to perform inorder to find sizing and wat tray the gas and liquid sud come in. thanks. ive got my pressure at 1atm gauge.
Any help will be appreciated thank you
