Poly Tropic Constant At Given Condition
7 replies to this topic
#1 bdabhi
bdabhi
  • 9 posts
Posted 14 August 2011 - 09:12 AM
Hi
Natural gas compressor has following condition:
P1 28.8 kg/cm2g
T1 297 K
P2 57.3 kg/cm2g
T2 370 K
By using this condition can i find polytroic constant for my centrifugal compressor as i have used PV^n as a basic formula for suction & discharge condition & derived n which comes as 1.47 but my Adaibatic constant k is 1.26 but k is always more than n as adiabatic work must be more than polytropic work . please help me to correct my n. something i am missing.
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 14 August 2011 - 11:33 PM
bdabhi,
The polytropic constant or polytropic exponent is related to the adiabatic exponent through the polytropic effciency. In equation form this can be represented as follows:
n/(n-1) = (k/(k-1))*ηpoly
where:
n = polytropic exponent
k = adiabatic exponent
ηpoly = polytropic efiiciency
The polytropic effciency may be considered approximately as 77-78% for a wide range of inlet volume flows to the compressor. Alternatively polytropic efficiency may be approximated from the following emprical correlation:
ηpoly = 0.0992 +0.2463*log10Q1-0.02167*(log10Q1)2
where:
ηpoly = polytropic efficiency
Q1 = inlet volume flow, m3/h (at inlet conditions of pressure and temperature)
The above should be able to provide you the polytropic exponent n.
#3 S.AHMAD
S.AHMAD
  • 786 posts
Posted 15 August 2011 - 03:55 AM
Dear bdabhi
Nothing wrong with your calculation except that you are not using absolute pressure you need to add 1.0332 to the pressure. My calculation shows n=1.49 Using this value in the polytropic relationship with adiabatic constant (k=1.26) namely
then we have polytropic efficiency of 63% which is a reasonable figure. If you know the flowrate at inlet conditions then use the equation given by ankur and compare the two figures
Edited by S.AHMAD, 15 August 2011 - 04:14 AM.
#4 bdabhi
bdabhi
  • 9 posts
Posted 15 August 2011 - 04:08 AM
Thanks Ankur
But as per polytropic constant formula n-1/n =LN(T2/T1)/LN(P2/P1) , value of N is more than adiabatic constant. I have aslo used the formula given by you for the above condition(Qi =7505 m3/hour @P 28.8 kg/cm2g & T 297K) which gives some illogical value like 1848 .0 for polytropic efficiency. i want to calculate efficiency after finding polytropic constant & based on polytropic constant i would like to calculate Polytropic power.
#5 S.AHMAD
S.AHMAD
  • 786 posts
Posted 15 August 2011 - 04:32 AM
Using ankur's equation and flowrate of 7505 m3/h the calculated polytropic efficiency is .728 or 72.8% so ankur's equation is reliable and can be used for comparison.
#6 bdabhi
bdabhi
  • 9 posts
Posted 15 August 2011 - 04:46 AM
Thanks S Ahmad
As per thermodynemics, value of n must be k>n>0, in this case why does the valyue of n is more than k ?
#7 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 15 August 2011 - 07:38 AM
bdabhi,
Which thermodynamic textbook did you refer for this? You have got it all backward.
For a given compression process following a ideal thermodynamic isentropic (reversible adiabatic) path, the isentropic efficiency is greater than the polytropic efficiency. Essentially a polytropic path of compression deviates from the isentropic path in the sense that there are infinitesmal amount changes in the gas characteristics when the isentropic compression process is broken up into infinitesmal steps. A polytropic path is thus less efficient compared to an isentropic path.
If you put it in terms of the equation, the value of n will always be greater than k when determining the work done on the system due to the fact that a polytropic process requires more work (power) than an isentropic process for the same compression ratio and the same volumetric flow rate.
Edited by ankur2061, 15 August 2011 - 07:41 AM.
#8 S.AHMAD
S.AHMAD
  • 786 posts
Posted 15 August 2011 - 07:37 PM
Dear bdabhi
Ankur has explained the thermodynamic part. Let me share with you actual plant data which were obtained sometime ago while I was working in an ammonia plant. P1=31.5 barg, T1=39.4C, P2=49 barg and T2=97.2C. These data give poly eff = 75% and n=1.65. The value of n = 1.65,that is greater than k=1.42. It seems that for n>k is quite common in the industry.
Let say if we have k=1.42 and n=1.3, these data give a poly eff = 128%. We know very well that polytropic efficiency cannot be greater than 100%.
Edited by S.AHMAD, 15 August 2011 - 07:50 PM.
