Hysys Simulation Of Gas Turbine Power Plant
Posted 15 August 2011 - 10:31 PM
I'm trying to simulate a gas turbine power plant using Hysys software.
I don't Know how to choose the Efficency of Compressor and turbine to find a real approximation of total produced power.
It would be appreciated if anybody could help.
Posted 16 August 2011 - 03:18 AM
This input ussually came from the Gas Turbine vendor
but for preliminary purpose just use hysys standard value of 75% adiabatic efficiency
Posted 16 August 2011 - 03:33 AM
Hi ali.jabbaran
Hi Again
Thanks for your kind attention
you are true, but my purpose from this values is estimating power plant output.
As you know in a Gas Turbine Power plant main part of energy consumed in air compressor.
I want to have a reasonable values for compressor and Turbine efficiencies in my simulation, so I can predict and relie on simulated total output power.
Posted 16 August 2011 - 03:44 AM
76 to 78% of polytropic efficiency
Edited by erwin.apriandi, 16 August 2011 - 03:45 AM.
Posted 16 August 2011 - 05:00 AM
Gas Turbine has an axial compressors with high efficiencies and hysys can model the centrifugal/reciprocating compressors. So be careful while modeling the compressor as the outlet air temperature is will be unrealistic in case of lower values of efficiencies mentioned in the earlier posts.
Posted 17 August 2011 - 04:45 AM
I saw in a simulation you have done:
You select 99% Efficiency for Compressor and 90% Efficiency for Turbine.
May I know what's the background of these values?
I need these efficiency values to relie on the total simulated power in Hysys.
Produced power in turbine and consumed Power in compressor (and so total power) change greatly with change in efficiencies.
It would be appreciated if you could provide me any references for proper simulation of a Gas turbine with Hysys.
Thanks alot.
Posted 17 August 2011 - 11:14 PM
Dear Padmakar S Karte;
Thanks alot.
The efficiencicies were modeled to match the results with the existing facility i.e. it is a retrofit simulation file. I tried to model it as a physical gas turbine with multistage axial compressor. The details like efficiencies will be available with the gas turbine vendors like GE, Siemens and others. The model I have submitted long back here in while replying to a similar topic is just an approach and honestly speaking I have very limited knowledge of the facility.
Posted 19 August 2011 - 11:38 PM
Posted 19 March 2012 - 09:32 AM
Thanks alot.
Hi ali.jabbaran
In this post you are talking about a simulation given to you from Padmakar S Karte. Could you tell me please where I can find this simulation. I suppose that Mr. Padmakar S Karte gave you the simulation through private message. Could you also sent me this simulation please. I'll really appreciate your gesture.
Let me know if it is possible
I'm looking forward for your message.
Thank you
Alex
Edited by alex.gutu, 19 March 2012 - 09:33 AM.
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
