Hi everyone
hope you all be fine. I want to know how I can open a newer version of Aspen with an older version. In which format I should save the newer one to open it with an older one?
Thank you very much for your help,
Nazi
Aspen Simulation
Started by Nazi, Aug 18 2011 11:05 AM
Posted 18 August 2011 - 11:05 AM
Posted 24 August 2011 - 04:34 AM
You cannot directly open a simulation saved in a newer version with an older version of Aspen Plus (it's a great way to "motivate" people to upgrade their versions right?).
However, I believe there is a way you can go around this issue. Ask someone with a recent version of Aspen Plus to open the document and 'Export' it as an input file (*.int). You can then open this file with notepad and edit it in a way that matches your Aspen Plus version (change databank names, etc.). Finally, you open a new Aspen Plus simulation choosing the modified input file.
I hope this works for you.
This link might be useful for your editing: http://www.che.ncsu..../AspenPlus2.pdf
Best Regards,
João Alegre Queiroz
Best Regards,
João Alegre Queiroz
Edited by Queiroz, 24 August 2011 - 04:36 AM.
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
