Hi Everybody,
We are designing a gas by-pass line with a manual globe valve (for throttling flow) and a manual ball valve (for opening and closing). Which should valve be positioned upstream and why?
Shan
Order Of Globe Valve And Ball Valve
Posted 19 August 2011 - 06:53 AM
Posted 20 August 2011 - 04:17 AM
Shan,
Ball valve should be located upstream with a minimum distance of 600 mm from globe valve.Otherwise low temperature situation would create due to j-t effect at downstream of globe valve may affect ball valve operation (open or close stuck).
Fallah
Posted 22 August 2011 - 03:42 PM
Thank you, Fallah. However, on the same token, J-T effect at downstream of ball valve may have negative impact on the globe valve also.
Posted 23 August 2011 - 01:33 AM
shan,
Thanks for your attention, but because the ball valve in drain lines is normally considered as FB (full bore) type, there is no concern about the J-T effect in its downstream.
Fallah
Posted 23 August 2011 - 07:11 AM
Hi Fallah,
It is intersting. Then, how about lqiud service? The valve order does not matter because there is no J-T effec. Is it right?
Shan
Posted 23 August 2011 - 08:48 AM
In case that the globe valve needs repair or replacement, the two ball valves are closed, with the main line (not the bypass) still in operation. Then the bypass section between the two ball valves is drained (there must be a (say) 0.75” drain line on the bypass line) and the globe valve is replaced. Otherwise the gas line (not only bypass) has to stop operation in order to replace the bypass globe valve. This cannot be avoided when you replace one of the ball valves, but these on / off valves are expected to rarely need maintenance.
Posted 24 August 2011 - 01:11 AM
Shan,
Generally yes, but mentioned arrangement (ball before globe with 600 mm distance) is mandatory for liquified hydrocarbons (avoiding the globe to be freezed due to low metal temperature).Of course this arrangement may be applied for all liquids for uniformity and simplification.
Fallah
Posted 24 August 2011 - 08:17 AM
Thank you again Fallah. I am convinced.
Posted 12 February 2013 - 02:16 AM
Edited by jklasers, 12 February 2013 - 02:18 AM.
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
