Centrifugal Pumps-Design Head And Shutoff Head
Posted 09 September 2011 - 05:54 AM
In one of the pump specifications, it is mentioned a minimum shut-off head of 15% more than the design head.
Why it is required. what if shut off head falls within 15% margin on design head.
Kindly clarify.
Thanks and Regards,
P.Sridhar
Posted 09 September 2011 - 09:12 AM
Dear Sir,
Kindly clarify.
Thanks and Regards,
P.Sridhar
Sridhar,
In basic design stage while the pump performance curve isn't available, it (shut-off head) is required to estimate the design pressure of piping and equipment located in pump downstream. For most pumps with almost flat curve 1.15 times of the design head could be a proper estimation.
Fallah
Posted 11 September 2011 - 07:24 PM
The shut-off pressure is normally used to decide on the casing and piping design after taking into consideration the maximum possible suction pressure ( e.g. relief valve pressure + elevation head).
Posted 18 September 2011 - 02:37 AM
Kindly let me know in the implication on pump performance, when shutoff head is less than 15% of design head.
The specification reads like this,
"The total head capacity curve shall be continuously rising from the operating
point towards shut-off without any zone of instability and with a minimum
shut-off head of 15% more than the design head."
Thanks and Regards,
P.Sridhar
Posted 18 September 2011 - 10:07 AM
Had he given more than 15 % it would have been a problem.
I would advise your ask for the performance curves from vendor to calculate the actual shut off with the highest density case to ensure the design pressure doesn't exceed your earlier estimate.
Posted 19 September 2011 - 11:31 AM
Posted 20 September 2011 - 11:32 AM
Posted 20 September 2011 - 12:22 PM
When the performance curve is not available, 120 % of rated head is considered as the shut off head.
Posted 20 September 2011 - 05:42 PM
Consider this resource ( free download) . It will support your query .
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
![]() ![]() Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , 14 Sep 2025 |
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
