Hi Everyone,
I work with pump / blower systems, and want to get a book that helps me understand piping and various components. I saw that on the site of FluidFundamentals.com they had two books, one is the Flow of Fluids through Valves, fitting and Pipe (Technical Paper # 410), and they have Piping Systems Fundamentals. Does any have both books, and can compare them to me so i know which to buy? Or if you have the book Piping SYstems Fundamentals, can you give me a review on it? I wanted to buy one of the books. Thanks in advance.
Technical Paper 410 Or Piping System Fundamentals
Started by zfarsh, Sep 28 2011 10:25 AM
which one to get?
Posted 28 September 2011 - 10:25 AM
Posted 30 September 2011 - 04:28 AM
Your first step is to check the students forum.
At the top of this is pinned the Crane Manual section.
There are lots of worked examples there plus some very expert assistance.
Art appears to have a $10 copy from 1957 but I think today you will be paying around $100 I think.
The two manuals are 410 and 410M (metric)
Then go to www.flowoffluids.com where details of the 2009 edition and pricing is available.
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
Technical/ Soft Skills To Work On This SummerStarted by Guest_LetharVerve_* , 20 Apr 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
