I have one query regarding non-condensing steam turbine - used to run a Compressor.
This turbine runs with HP steam and exhaust is LP steam.
My question is that - when i want to find the max. flow from the turbine - what inlet conditions should i take.
And what will be the basis for knowing the max. flow from the exhaust.
Any one can help me on this.
Thanks.
Posted 03 October 2011 - 11:04 PM
Posted 04 October 2011 - 12:09 AM
chiks,
This is a relief valve forum. Post your query on the "Industrial Professionals" forum.
Posted 04 October 2011 - 12:16 AM
I want to know the max. flow through steam turbine - as i want to size the PSV in the LP steam exhaust piping.
Sorry for confusion in the query.
Thanks.
Thanks.
Posted 04 October 2011 - 12:49 AM
For any centrifugal compressor the affinity laws apply, which means the following:
N1 / N2 = Q1 / Q2
and P1 / P2 = (N1 / N2)3
where:
N = speed, rpm (1 and 2 represent two sets of conditions)
Q = Volume flow rate, m3/h (1 and 2 represent two sets of conditions)
P = power, kW (1 and 2 represent two sets of conditions)
It is obvious that at the maximum volume flow rate for a given speed and head the power consumption will be the highest which in turn means that if it is a steam turbine driven compressor the steam consumption will be the highest.
N1 / N2 = Q1 / Q2
where:
Posted 04 October 2011 - 03:08 PM
Following old standard (~1980) for PSV on non condensing steam turbines says:
-Though not mandatory, large non condensing turbines usually have a PSV at exhaust pipe, set at a pressure between 1.1 of normal exhaust pressure and turbine case design pressure.
- Relieving capacity is recommended to be specified by turbine manufacturer, otherwise it should be equal to nominal flow (*)
- Exhaust steam block valve should be "car seal open".
Note (*) Nominal flow is actually maximum flow under normal condition, look at post by Ankur.
Hope it helps a bit.
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
