i have designed a absorber for the removal of SO2 from ethanol,ether and water mixture using dil.NaOH solution.reaction product is NaHSO3.
inlet gas temperature is 128 C
outlet =========== 80 C
inlet solution temperature is 25 C.
outlet may be at any temperature.
design pressure is 1 atm.
tower is packed with 1 in ceramic intalox saddles.
tower dia is 3.6 ft.and height is app.20 ft.
plz seggest me any suitable material of construction for this absorber under these process conditions.and also give some reason for ur nice answer for this.
my email add is
secretpearls33@hotmail.com
secretpearls33@yahoo.com
pleaze, guide me in this problem.
Muhammad Naeem
(final year Chemical Engineering)
(Engineering University,Lahore,Pakistan)
Material Of Construction For Caustic Absorber
Started by Guest_Muhammad Naeem_*, Aug 27 2005 11:42 AM
Posted 27 August 2005 - 11:42 AM
Guest_Ahmed Vawda_*
Posted 31 August 2005 - 05:11 PM
QUOTE (Muhammad Naeem @ Aug 27 2005, 11:42 AM)
my email add is
Muhammad Naeem
my email add is
Muhammad Naeem
Dear Mohammed
You havent mentioned the concentration of the SO2
At 128 deg C, the SO2 is in the dewpoint zone already and the choice material of construction will not be carbon steel
I would use SS316i. It is not too expensive and has good corrosion resistance to the product gases you are working with.
Dont forget to consider foaming problems. You might want to fit a demister at the top. Knitted filament of polypropylene is a popular solution to minimise entrainment.
Ahmed Vawda
HOD Teh Services
www.unitedsugar.com
Psv Body Material Of ConstructionStarted by Guest_QuantumEng_* , 07 May 2024 |
Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
Scrubber(Absorber) In Apsen PlusStarted by Guest_Seonwoo_* , 20 Mar 2025 |
Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
Material Balance ProblemStarted by Guest_vinnay1999_* , 18 Oct 2024 |
