Sulfuric Acid Plant Simulation In Hysys
Posted 26 October 2011 - 03:19 PM
Does any body here have the experience of simulating sulfuric acid plant in HYSYS ?!?!
I want to know the accuracy of the available thermodynamic packages in HYSYS for this specific case.
ARM
Posted 28 October 2011 - 02:38 AM
please refer to the reference
http://www.aspentech...ine 10-2010.pdf
Posted 28 October 2011 - 04:38 AM
Part of the simulation (gas sweetening plant) is done in HYSYS. The removed H2S is used as raw material for production of sulfuric acid.
I want to have both plants in one simulation file.
I searched for simulation of sulfuric acid plant in HYSYS. So far, nothing ...
Posted 28 October 2011 - 10:19 PM
with v7.x, aspen integrated their thermo properties across Hysys and Aspen Plus, therefore expanding the overall database and use the same methods across.
having said that, i never used either in simulation of Sulphuric Acid plants. I believe these designs depend more on know-how rather than plain physics.
cheers,
sm
Posted 31 October 2011 - 02:24 AM
And there are some setting that you have to do before you can use this, so if aspen plus is ok for sulphuric acid simulation I believe this can be realiable to. But I'm not sure since I never use it before, but I have use Aspen Properties and it giving better results for steam system simulation using ASME steam table
Edited by erwin.apriandi, 31 October 2011 - 02:25 AM.
Posted 23 February 2012 - 11:46 AM
I really need help in this regard.Thanks in advance
Posted 27 February 2012 - 02:10 AM
I did the Sulphuric Acid plant simulation in HYSYS. With Chemcad I have no experience.
Cheers,
ARM
Posted 17 March 2013 - 03:51 PM
Posted 25 March 2013 - 10:41 AM
Divya,
Which fluid package did you eventually use for H2S04?
#10
Posted 14 July 2013 - 07:31 PM
Hi.....
u can use Glycol package or NRTL package, but u must have to specify Activity coefficients for complete and accurate absorption of H2O or SO3 in H2SO4.......
as hysys as well as Aspen , both dont have Equilibrium data , therefore if u dont specify Activity coefficients in Fluid package manually, u cant get moisture free air at dryer outlet and SO3 absorption in H2SO4 at recommended flows.......
regards,
#11
Posted 17 September 2014 - 02:53 AM
Hi.....
regards,
Well, this depends on type of the sulfuric acid production process. The process that I simulated was very old (burning H2S and converting to SO2, then converting SO2 to SO3 in presence of vanadium oxide and at the end reacting SO3 with water content of diluted sulfuric acid). I used HYSYS and considered two different thermodynamic packages. Up to SO3 scrubber (scrubbing SO3 with diluted sulfuric acid), I considered PRSV. From SO3 scrubber to the end of process I used Electrolyte package from ASPEN Properties in HYSYS environment.
I compared the result of Simulation with real plant data and the result of comparison was very close to real data (difference less than 2%).
Edited by ARM, 17 September 2014 - 03:26 AM.
#12
Posted 01 October 2014 - 07:44 PM
Hi Divya Singh,
Cheers,
ARM
hello peale can you send me the file , i need it to and thanks a lot
#13
Posted 03 October 2014 - 01:03 PM
I doubt Hysys would be able to model the sulfuric acid plant very well. It is not generally very good for acid/base reactions. Instead I would use Aspen Plus, ProMax, or ChemCAD. If you can use Aspen Plus properties in Hysys, it should be accurate, too.
Now, you also stated that you made a Hysys model of your Amine Sweetening unit. This is also not recommended due to the inaccuracies found in Hysys for ions (again an acid/base deficiency).
Of the four simulators mentioned above, I would always choose ProMax for Amine Sweetening. If you want to have the Sulfuric Acid plant modeled in the same simulator, it would make sense to use ProMax for all of it, however, ChemCAD or Aspen Plus can probably do the Sulfuric Acid part just as well.
#14
Posted 08 October 2014 - 02:08 AM
Hi RockDock,
You are absolutely right. HYSYS is not the best to simulate the Sulfuric Acid Plant, but since you can use ASPEN properties in HYSYS environment the result is acceptable. I also compared end result versus real plant data and it was acceptable.
For Amine plant, it is possible to use Amine package in HYSYS as well. The accuracy is acceptable. I have done the simulation for MEA plant and the result was very close to plant data.
#15
Posted 13 November 2014 - 12:50 AM
![]() ![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
