I would like to simulate distillation column with thermosyphone reboiler which doesn't act as an ideal stage. I used TOWER column,in specs I didn't include reboiler and condensator,I put them separetly as shown in attachment,reasons why,because reboiler doesn't act as stage, and there is partial condensation-is this corect way or can't be done that way ?
I used SRK model,components are H2,CH4,C2H4,C2H6 and some CO
Temperature range is from -30 to -7 °C
Pressure is from 20-24 kg/cm2 G
To start simulation I cut recycling streams,thus making reflux and reboiler streams to be products (6, 11). I replaced them as feed streams( 7, 12 ) with specs I put in. There is also divider before reboiler as I have bottom product.
It's all seen in attachment
The problem is I can't ger proper results, any idea where I got wrong or what proper procedure is for this type of simulation, or how to correctly use cut streams and proper use of initial flag option in tower specs ?
Thank u very much for any given answer !
