Back Pressure Regulating Valve
Started by chandru, Nov 10 2011 01:36 PM
Posted 10 November 2011 - 01:36 PM
Dear all,
I am using a back pressure regulating valve in the pump recycle for maintaining constant pressure in the pump discharge.
Pump is used for water spray system.Pump rated point is 15.2 m3/hr at 95 m.
On what basis i have to provided set point to back pressure regulating valve in order to maintain the constant pump discharge pressure?
Posted 20 November 2011 - 06:53 AM
No P&ID ,No Control schemes not even types of pump !
Please understand this forum has engineers ,no magicians
Posted 21 November 2011 - 02:03 AM
Dear all, I am using a back pressure regulating valve in the pump recycle for maintaining constant pressure in the pump discharge. Pump is used for water spray system.Pump rated point is 15.2 m3/hr at 95 m. On what basis i have to provided set point to back pressure regulating valve in order to maintain the constant pump discharge pressure?
chandru,
The set point of the PCV should be the corresponding pressure value of the pump minimum flow.
Fallah
