Brine Physical Properties Calculator
brine eos
#1 marlog
marlog
  • 3 posts
Posted 16 November 2011 - 06:33 PM
I am looking to calculate the critical properties as well as the following physical properties for a 23000 ppm brine at T=95 C and P=282 atm:
Viscosity
Compressibility
Density
z-factor
I've seen some correlations in the literature but would like to be more exact. I'm wondering if anyone knows of a good online software package so that I can automate this process for several different scenarios.
Thanks,
Marlo
#2 JMW
JMW
  • 166 posts
Posted 18 November 2011 - 07:54 AM
I think you may need to be more specific.
A literal interpretation might assume you could refer to either sodium chloride brine or potassium chloride brine. But the term "brine" also has become a generic for any refrigerant. For example, in pharmaceutical applications where brine (NaCl solution) was once used as a refrigerant the term is used generically to refer to ethylene glycol solutions.
Various industries have many such generic terms that can mean different things to different people.
#3 marlog
marlog
  • 3 posts
Posted 18 November 2011 - 03:09 PM
Hi JMW, thanks for your reply.
This is for a geologic application and it's safe to assume an NaCl solution. A brine we define as >30,000 ppm NaCl so this is technically more like seawater. Does this help?
#4 marlog
marlog
  • 3 posts
Posted 28 November 2011 - 08:50 AM
For anyone interested, I ended up using a spreadsheet from the following website:
http://www.henderson.../Downloads.html
