Can anyone provide xls sheet for design of condenser & evaporator in compression refrigeration cycle or method
Condenser & Evaporator Design In Carnot Cycle Of Refrigeration
Started by hemantwarhekar, Nov 18 2011 09:21 AM
Posted 18 November 2011 - 09:21 AM
Posted 19 November 2011 - 12:13 PM
Hemantwarhekar,
Like many aspects of process design, refrigeration systems cannot be reduced to a spreadsheet. There are a number of questions that you should consider first:
Then, commence the design by the usual method of making a heat balance, and calculating the flow of refrigerant. Then you can determine the heat duties, the compression power, and the piping sizes.
There are a number of ways that the system can be optimised to reduce power, reduce costs etc, which require a grasp of the process. None of this work is done on a spreadsheet.
Paul
- what is the required temperature of the cold end (evaporator?
- what is the required temperature of the hot end (condenser)?
- what refrigerant fluid will you use?
Paul
![]() Rising Film EvaporatorStarted by Guest_lanco_* , 23 Jun 2025 |
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
