Any one have information about corrosion in benifield system and what are the major rasons of high iron contents in benfield absorption sytem
High Iron In Benfield System
Started by waheedbhatti, Nov 19 2011 11:04 AM
benfield absorption system
Posted 19 November 2011 - 11:04 AM
Guest_Attyub194_*
Posted 20 November 2011 - 01:59 AM
Dear Waheed
Good day
The most obvious reason is lack of deficiency of Vanadium or Potassium nitrite in the system. Please check the analysis at immediate out let of absorber and stripper as well
Please note that obtaining samples at the downstream of activated carbon filters will definitely give wrong results due to reduction properties of activated carbon used for de-coloration
As per UOPL recommendation,total vanadium should not be less than 0.7 wt percent and V5 should not be less than 0.4 wt percent.
This is a very serious issue and need to address immediately as it has resulted in equipment failure in past.Please, also do consult UOPL
Best regards
Good day
Best regards
Posted 21 November 2011 - 08:37 PM
have u any literature regarding corrosion and reaction details
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
Iron Sulphate Heptahydrate ProductionStarted by Guest_baam353_* , 19 Jul 2025 |
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
