hi
According to API 527 there are some allowable leakages for psv seat tightness test at 90%set pressure.but it is not mentioned for pressure less than 90% set pressure.shall it be zero leakage for pressure<90%set pressure or not?
regards
rohollah
Psv Seat Tightness
Started by rohollah, Nov 30 2011 04:42 PM
Posted 30 November 2011 - 04:42 PM
Posted 30 November 2011 - 05:36 PM
No, there's always going to be some amount of leakage, it's just not quantified at pressures < 90% of set pressure. Obviously, at lower pressures the leakage rate will be less.
If your tolerance for leakage is low, then consider using a soft-seat valve or a rupture disk under the PSV.
Static Charge Buildup On Elastomer Seat Of Vacuum Relief ValveStarted by Guest_JamieG_* , 24 Jan 2017 |
Valve Seat Material SelectionStarted by Guest_Blesson_* , 10 Oct 2016 |
![]() Valve Proving Test Or Leak Tightness Test.Started by Guest_muddu4_* , 24 Oct 2014 |
Integrity Tightness Test And Leak TestStarted by Guest_ehsan1982_* , 03 Sep 2013 |
Air Leak Tightness TestStarted by Guest_deltaChe_* , 24 Dec 2011 |
