hi,
can any one share a document that can provide adequate information about Well head arrangement and provide function of each valve in the well head TREE.. m very thankful .
Well Head Arrangment And Functions Of Valves In Well Head Tree
Started by M.Sadiq, Dec 01 2011 01:23 AM
Posted 01 December 2011 - 01:23 AM
Posted 01 December 2011 - 08:20 PM
Hi Mama,
For the most simple oil producer, you generally have two casing valves and two tubing tree valves. The two casing valves provide access to the annular space between the production casing and the production tubing. The tubing tree valves provide access to the production tubing. As you can see, there are several additional pieces of equipment (and possible loops for fluid circulation) in the piping downstream of the casing valves and tubing tree valves. What information are you looking for specifically?
TheLeftCoast
TheLeftCoast
Edited by theleftcoast, 01 December 2011 - 08:22 PM.
Posted 23 April 2012 - 08:35 AM
Posted 15 May 2012 - 06:49 AM
Here's a sketch showing Wellhead valves arrangement.
Posted 15 May 2012 - 07:27 AM
Hi Khan Pathan,
Attached wellhead PFD, sketch and other links below, Hope you find this interesting.
http://www.posgrip.c...ts/hg_18_34.htm
http://www.i.serenee...f-wellhead.html
http://instrumentation.web.id/?p=400
http://www.ntnu.no/r...vesterkjaer.pdf
http://www.most.gov..../PE02013_QA.pdf
http://www.standard..../u-cr-003r1.pdf
http://www.osti.gov/...quB/6417080.pdf
http://www.naturalga...on.asp#wellhead
http://www.petro-techna.com/fl_refinery3.swf
Shivshankar
Shivshankar
Edited by Shivshankar, 16 May 2012 - 11:01 AM.
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
![]() Breather Valves - Liquid Movement In Breathing ScenarioStarted by Guest_panoska_* , 14 Dec 2024 |
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
![]() Discharge Head Or Differential Head, Pump CurveStarted by Guest_panoska_* , 11 Nov 2024 |
![]() Centrifugal Compressors (Actual Vs Polytropic Head)Started by Guest_panoska_* , 25 Oct 2024 |
