Truck liquid is unload using pressurized nitrogen flow to inside truck tank. Unload liquid flow rate = 167 kg/hr. Density =1000 kg/m3. nitrogen inlet pressure to the tank = 1kg/cm2g. how much nitrogen flow rate required to fill for replacing the volume? Truck volume 20 m3.
kindly reply me..
Pressurized Nitrogen Flow Rate?
Started by prabhakaran.nitt, Dec 07 2011 03:16 AM
Posted 07 December 2011 - 03:16 AM
Posted 07 December 2011 - 05:40 AM
kindly reply me..
prabhakaran.nitt,
Total required nitrogen volume (assumed the tank initially is full of liquid) would be 20 cu.meters at pressure of 1 kg/cm2.g
The rate of nitrogen flow rate, if system's hydraulic change during unloading wouldn't cause liquid flow rate to be changed, is 167 lit/hr.
One more point: With such low unloading flow rate the total unloading time would be around 120 hours!
Fallah
Edited by fallah, 07 December 2011 - 05:44 AM.
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Calculating Gas Flow Rate Without CvStarted by Guest_worrier_* , 25 Nov 2025 |
