Hi All,
I am using Aspen Hysys 7.3 for my refinery adequacy simulation. I wish to use KG tower 5.0 utlity for doing column adequacy check.
Can anybody please tell me how I can export the column profiles from Aspen Hysys 7.3 to KG tower 5.0.
The KG tower needs a " .rep" file format, but the Aspen report is generated in .Txt and other forms but I am not able to find the .rep format.
Please help.
Thanks in advance.
Exporting Tower Profiles From Aspenhysys 7.3 To Kg Tower
Started by B-2 Spirit, Dec 19 2011 06:58 AM
aspenhysys 7.3 to kg tower
Posted 19 December 2011 - 06:58 AM
Posted 19 December 2011 - 07:24 AM
Alok ,
If u have registered in ASPEN HYSYS support center then you will get solution.
So, Request you to register & follow below solution ID.
Refer solution ID - Solution ID: 131574
Improved in HYSYS V7.3 - Tray and packed column hydraulics, including export to Koch-Glitsch's KG-Tower and FRI's DRP design / rating programs.
I think this will help u to resolve your probelm.
Jatin
Jatin
Posted 19 December 2011 - 08:11 AM
Thanks Jatin,
Had a look into the utility and export tab also, it seems promising and i hope I will able to use it successfully.
thanks a lot
cheers,
Alok
thanks a lot
cheers,
Alok
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
Flash Tower With Tray In Deoiling Of Wax?Started by Guest_AnbIran_* , 01 Jul 2024 |
![]() Absorber Tower Can't Be ConvergedStarted by Guest_dynamichysys_* , 14 Jun 2024 |
