At our FCC a certain amount of catalyst is vented to atmosphere due to the loading system.
We are searching for a cleaner way to transport catalyst from the storage container into the storage silo.
The loading of fresh catalyst into the silo is done by creating vacuum with a steam ejector. Unfortunately, some of the catalyst it is drawn into the ejector and released into the atmosphere.
We would like to use a dust free system to refill the silo and stop the use of the steam ejector.
is there any recommened dust free system or even mechanical system that is used for that purpose?
Thank you,
Chen
Fcc - Dust Free System For Catalyst Loading.
Started by josh_l, Dec 29 2011 03:48 AM
fcc catalyst dust free
Posted 29 December 2011 - 03:48 AM
Posted 30 December 2011 - 06:57 AM
what are physical properties of the catalyst e.g. its bulk density, dynamic flow rate??
Posted 03 January 2012 - 09:45 AM
the catalyst particle size is between 20-100 micrometer, with an average size of 65 micrometer.
the bulk density is 0.85 g/ml
I don't know how much catalyst goes throw the ejector. I can assume that around 50kg/hr is lost.
we usually refill the fresh catalyst tank with a 20 tons batch. since it takes around 8 hours to do it, the flow rate into the tank is 2500kg/hr. we assume that 2% of it (which is the percentage of the very small catalyst particles) goes throw the ejector.
Posted 04 January 2012 - 06:32 AM
I assume that you are using pneumatic conveying system for transfer of catalyst, You should install a reverse jet dust collector for this application
![]() Free Vent For Api 650 Tank - Bug Screen / Bird Screen RequirementStarted by Guest_Cabbarbeybaba_* , 03 Jul 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
Inlet Line Not Free DrainingStarted by Guest_Asifdcet_* , 07 Apr 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
