i want to design a spray drying system to get 10 ton/hr dried material from 110 ton/hr slurry with11% solid content but i unfortunately i dont have any experience on drying operations. so far i have calculated heat transfer coefficient from the droplet (dia of the droplet i have assumed) ( hcD/Kd) = 2 + 0.6(D*v*ρ/μ )
and then rate of evaporation of water from the droplet. M = hc*A*(∆T)/λ. now to get the residence time
should I use Mw/M but i have a doubt this mass (of droplet) also has suspended solids.Also volume of the dryer depends on the residence time so i am stuck to get a perfect design. I would be grateful to you if you
guide me to such design.
Also cost of the dryer depends on size(volume) or just capacity of drying ?
and if I use other means of drying (drum or tunnel ) which of them is economical ?
Spray Drying
Started by kate1989, Dec 29 2011 02:19 PM
Posted 29 December 2011 - 02:19 PM
Posted 30 December 2011 - 01:19 AM
Dear,
I advise you to please refer to Spray Drying Handbook by Keith Masters. As it contains all the calculations related to spray dryer design and also would guide you in selecting the economical spray dryer.
Posted 30 December 2011 - 04:43 PM
thanks for your response.......i tried to look for the book but didnt find it so far. i just need the flow of material and air and temp and also the size of the dryer. its like a black box model n not really need a detailed design though
Posted 31 December 2011 - 03:28 AM
The attached file will help you, this file I used when I was working on Unilever's Detergent Spray drying project
At What Temperature Does Water Evaporate When Drying A Solid ?Started by Guest_Checster_* , 30 Nov 2022 |
Fuel Gas Skid Gas DryingStarted by Guest_kengor10_* , 15 Feb 2022 |
Spray DryerStarted by Guest_Zahid54_* , 04 Aug 2021 |
Polymer Drying In Unisim R480Started by Guest_charb_* , 18 Jun 2021 |
Firewater Nozzle Spray OverlappingStarted by Guest_stu_* , 18 Feb 2021 |
