I am a mechanical guy trying to understand the issue of rotational speed (N) about centrifugal compressors. It is my first time being exposed to this math, so I used GPSA handbook and Royce Brown's - Compressor Selection & Sizing Book. Also, the spreadsheet I set up for myself, gave me numbers that closely match one of the speadhseets I found here on this site by a great contributor on compression issues. (Thank you SIr)
Let's say hypothetically I have an existing (brownfield) multi-stage centrifugal and the vendor info is non-existent except for these few items:
- it is a tandem-driven series dresser-rand D8 R7 B centrifugal (D8 = datum type 8, R7 = 7 stages, B = means back-to-back)
- a solar turbine driver (directly connected = no gear between driver & compressor)
(1) I need to understand the rotational speed N, I made the assumption that each compressor has 7-impellers (and diffusers, and plenum/straightener vane arrangement depending on the model etc.)? Is this correct?
(Caveat: as a mechanical when I hear 7 stages, I am thinking, this machine has 7 impellers)
(2) Someone else, prior to me joining this research, used language in a report to indicate "stage" to mean each representative compressor? Is this correct?
(Caveat: From my understanding he took 1st stage to mean "first stage compressor". I assumed this person is from a process/chemical background person, since his calculations are based on one compressor as a compression unit. Sort of what a positive displacement compressor would behave like.)
(3) I have only understood how to do one calculation at a time for one compressor, has anyone come across calculation methods for tandem-compressors? What are the tricks to do this? (Please don't say ask the vendor!)
(4) Can I use the Nominal Rotational Speed, instead of the actual Rotational Speed when I publish my findings to avert controversy?
(Caveat: I am trying my best to not make this equipment an issue about the mechanical team vs. process team)
I hope you can share some thoughts.
Edited by M.Salah, 29 December 2011 - 05:35 PM.
