I don't have a copy of API 521, but I'm hoping that the answer is in there and that someone will pass it along.
Here's the question. Emergency depressuring valves are recommended for systems comprised primarily of vapour (i.e. compressor systems, etc.). Is there a pressure below which depressuring valves are not considered necessary?
Thanks,
RJ
When Is A Depressuring Valve Required?
Started by Guest_RJ_*, Sep 20 2005 04:56 PM
Guest_RJ_*
Posted 20 September 2005 - 04:56 PM
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
Hysys Depressuring Utility Pressure QuestionStarted by Guest_cammycheme_* , 15 Aug 2025 |
Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
