Am in my second part of a design project, I am designing an HCl column within a VCM plant using the balanced process. I would appreciate any books or resources that may be helpful to me in designing the column.
Thank you for your assistance.
Designing Hcl Distillation Column In A Vcm Plant
Started by swaiba, Jan 26 2012 01:35 PM
Posted 26 January 2012 - 01:35 PM
Posted 27 January 2012 - 03:59 AM
You should refer to Distillation design by H.Z. Kister for the detailed design, and distillation dynamics and control by Pradeep B. Deshpanday
Posted 03 February 2012 - 01:50 PM
ZAK- Thanks for your help.
I have looked at other books as well, but I am somehow stuck on finding operating conditions of the column. Any idea how I could do that in order to find the relative volatilies with regards to Light key and Heavy Key?
Appreciate your assistance.
Posted 06 February 2012 - 08:18 AM
You can also simulate the Plant on ASPEN PLUS or PROSIM PLUS
Posted 08 February 2012 - 02:41 PM
I have carried out some calculations and am stuck in finding the reflux and number of stages using fenske's equation. I would like to know if I can use the attached equations if my column has liquid and vapour feed since my q will not be equal to 1.
If you have any suggestions on how to go further with or use alternative calculations, please do not hesitate to add in.
Swaiba
Swaiba
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
