Hello to you all,
I want to use a molecular sieve in unisim for an assignment to separate ethanol from water. Ive used a distillation column but this cant separate further than ~93 % EtOH on mass basis due to the azeotrope. I want to obtain 99,9% pure EtOH. Is that possible with a sieve? I have no experience in that type of unit.
Kind regards,
Willem
Molecular Sieve In Unisim?
Started by eta_!, Jan 27 2012 10:03 AM
Posted 27 January 2012 - 10:03 AM
Posted 01 February 2012 - 08:46 AM
Willem,
The more effective method of separating ethanol-water mixture is to use membrane separation using a membrane method known as pervaporation, which is particularly useful when trying to separate azeotropic mixtures.
For explanation of "pervaporation" refer the link below:
http://en.wikipedia....i/Pervaporation
Molecular sieves can also be used but the process is energy intensive as per the link provided below:
http://www.ethanolpr...ne-integration/
Another link provided is a research paper on membrane pervaporation:
http://desline.com/articoli/7256.pdf
A link for discussion on molecular sieve for ethanol dehydration can be found at:
http://www.usbcd.com...0414/11161.html
As far as modeling of molecular sieve is considered it can be done by providing it as a splitter in HYSYS as advised in the link provided below:
http://www.cheresour...eve-simulation/
Due to my lack of familiarity with UNISIM, I am not in a position whether molecular sieve can be modeled in UNISIM.
Hope this helps.
Hope this helps.
Posted 02 February 2012 - 02:58 AM
Dear Ankur,
Thank you very much for your answer and usefull links! This pervaporation method I had not considered.
Kind Regards,
Willem
Kind Regards,
Willem
Unisim SoftwareStarted by Guest_TunTun_* , 15 Oct 2025 |
Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Molecular Sieve Regeneration At High PressureStarted by Guest_Victor_process_Engineer_* , 07 Jan 2025 |
Pid In Hysys/ UnisimStarted by Guest_NnN21_* , 01 Oct 2024 |
Adding Inlet To Compressor Through Vba (Hysys/unisim)Started by Guest_Matylda_* , 30 Jul 2024 |
