I am trying to calculate the radiant heat from the sun into a potable water piping network so I can size a heat exchanger to keep it cool enough not to scald people. It is a circulating system, I have a flow rate of the circulation. Ideally I would like to find a duty per 100 feet of pipe or something similar.
The pipes are carbon steel and insulated. Any ideas on how I would go about this? Can I disregard the radiant heat because of the insulation and just go with the air temperature? I can handle air temperature heat exchange, it's just the radiant heat that is puzzling me.
Calculating Radiant Heat From The Sun Into Insulated Pipe
Started by boginator, Feb 06 2012 10:50 AM
Posted 06 February 2012 - 10:50 AM
Posted 07 February 2012 - 01:25 AM
boginator,
Your question relates to a pipe but the same principles can be applied for solar radiation absorption for the cylindrical portion of a tank to a pipe.
For discussion on heat-up due to solar radiation for a tank refer the link below:
http://www.cheresour...4455#entry44455
Posted 08 February 2012 - 09:42 AM
Thanks Ankur. That's exactly what I was looking for.
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
