I have steam at 78barg and 300 deg C flowing through a pipe of 600# class, A105 (Carbon Steel) and a flowmeter is connected to it. Can I use SS316 as its wetted material? Do we need to change the pressure rating of piping and flowmeter to use SS316 for wetted material. Which ASME code to refer for such material selection. Is ASME B 16.34 of use for in deciding material?
Similar doubt what I have for the Valve. If the valve is 600# material for similar working fluid and flow conditions, how to decide on the trim material.
Shaji
Vortex Flowmeter Wetted And Valve Trim Material
Started by shajige, Feb 15 2012 12:33 PM
material selection flowmeter material valve trim material
No replies to this topic
Posted 15 February 2012 - 12:33 PM
![]() Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
