Good Evening,
I am currently desiging a heat exchanger to heat Air from 10 oC to 110oC and cool flue gas from 1259.4 oC to 725 oC.
As both fluids are gases, i would like to know if it is advicable to use a shell and tube heat exchanger?
I read online that the convertional gas-to-gas heat exchanger is vertical shell and tube heat exchanger
Thank You Very Much
Kind Regards
Paul
Heat Exchanger Design
Started by djdemzy, Feb 15 2012 01:25 PM
Posted 15 February 2012 - 01:25 PM
Posted 15 February 2012 - 04:11 PM
This appears to be an air preheater of some kind. It would not be a conventional shell-and-tube. Because of the low heat transfer coefficients on both sides, there needs to be some kind of extended surface.
Posted 16 February 2012 - 02:25 AM
Posted 17 February 2012 - 01:13 AM
As srfish mentioned your application is air preheater.One of good example is heat recovery excahger in Power industry, when outlet flue gas from boiler used for preheating of air.Take a look
in following link for some kind of this type of exchangers:
http://www.airprehea...?cat=1&subcat=9
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
