hi,
I'm doing a HYSYS simulation of a hydrotreatment reactor and I have the kinetics for the benzene hydrogenation and relatives rates for other components. how do I enter these relative rate? I put the stoechiometric coefficient for the toluene reaction and I re-entered the kinetic of benzene with a factor but it doesnt work. In the kinetic, i use only the benzene concentration, the hydrogen concentration and the cyclohexane concetration, the toluene only appears in the stoechiometric part ... is that the way to do it?!
thank you
Hysys Relative Rate
Started by TONYTHEREXOR, Feb 19 2012 02:53 PM
No replies to this topic
Posted 19 February 2012 - 02:53 PM
Calculating Gas Flow Rate Without CvStarted by Guest_worrier_* , 25 Nov 2025 |
