Hi
I am using ChemCad to try to model the amine regeneration section of the SCOT Process.
The difficulties I am having are to do with modelling the absorber and stripper in ChemCad. From what I have found out I think I have to use a SCDS column but am not too sure. Does anyone know how to do this?
The amine I am using will be MDEA and the columns also specify the number of stages required and the stages at which the feeds enter the column which I am not sure how I do.
Thanks for your time
Amansuad
Absorbers And Strippers In Chemcad
Started by AmanSuad, Feb 21 2012 07:27 AM
chemcad absorber stripper amine mdea scot
No replies to this topic
Posted 21 February 2012 - 07:27 AM
Simulate Desiccant Dehumidifier In Chemcad 7.1.2Started by Guest_Tamar_* , 15 Dec 2023 |
Dew Point Margin In Strippers & Fractionation ColumnsStarted by Guest_Venkat @89_* , 05 Sep 2023 |
Reg: Side StrippersStarted by Guest_halkeshhulk_* , 18 Jun 2023 |
Design Spec Equivalent In Chemcad V7Started by Guest_CHEMSTRONG_* , 29 Apr 2022 |
Stream Reference Module In Chemcad V7Started by Guest_CHEMSTRONG_* , 29 Apr 2022 |
