I am calculating freezing point depression of binary systems as water-methanol, water-ethanol etc. in Prode Properties
the procedure gives for water-methanol errors of 3-8 K against experimental data at different compositions with Wilson model, with NRTL errors are about the same, I would guess that a selection of different BIPs could improve the accuracy of these predictions, how can I regress from a experimental values (i.e. I have a few freezing point values as function of volume concentration of solvent in water and I wish to use a model to interpolate the whole range) ?
Thank you for assistance.
Freezing Point Depression In Properties
Started by mrbabu, Feb 22 2012 02:26 AM
freezing point depression liquid solid equilibria prode properties solvent water
Posted 22 February 2012 - 02:26 AM
Posted 22 February 2012 - 06:40 AM
with the solid model in Properties you need a reliable method to calculate liquid fugacities at operating conditions, Wilson (or NRTL) do not work reliably for water at temperatures well below 0.0 C, you may try different models as CPA or SAFT but I am not sure about the results for this specific mixture.
As alternative you may model solid-liquid equilibria based on solid saturation pressure correlation which is available in Prode Properties databank.
Posted 09 March 2012 - 04:56 AM
thanks,
I have not SAFT installed in my version, however I was able to correct values and results are acceptable (for my purposes).
Physical Properties Of Liquid Discharge For Kod SizingStarted by Guest_mahmooddalvi09_* , 26 Feb 2025 |
Kerosene Flash Point TroubleshootingStarted by Guest_zuberattan_* , 25 Oct 2009 |
![]() Negative Pressure At High Point?Started by Guest_mychemicalromance0425_* , 17 Aug 2024 |
![]() Air Humidity PropertiesStarted by Guest_alaasleem2026_* , 19 Jul 2024 |
