Hi all,
I'm facing the problem with hysys,when try to get the steam data by using ASTM Steam Property Package.These data doesn't match with Standard Steam Tables Data.
So,kindly suggest alternativies for this problem.
Phani Kanth
Why Hysys Steam Property Data Is Different Compare To Steam Tables Dat
Started by Phani Kanth, Mar 12 2012 12:00 AM
power plant simulation
Posted 12 March 2012 - 12:00 AM
Posted 12 March 2012 - 03:32 AM
Phani Kanth,
Which data do you have problem with? Is it enthalpy values?
Posted 12 March 2012 - 04:58 AM
@pavanayi,
Thank u for reply,
Yes problem with enthalapy values.
Thank u for reply,
Posted 12 March 2012 - 07:15 AM
Phani Kanth,
The reference state for enthalpy calculation for Hysys is different from that of steam tables. That is why the enthalpy values are different in Hysys / steam tables/ any other different source.
But normally you are only concerned with ΔH (change in enthalpy) and not absolute values. For all calculations, you need to calculate change in enthalpy between two conditions.
Take two conditions for steam (ex, condition1: 2 bar a, 150°C and condition 2: 10 bar a saturated), and calculate ΔH between the conditions using both Hysys values and steam table values. You will find your answer there.
Hope that helped.
Hope that helped.
Posted 12 March 2012 - 09:26 AM
reference valueare differentbetween the tablesand the simulator,however the delta are equal.
Posted 12 March 2012 - 10:08 PM
Phani,
I agree with pavayani but to confirm this, could you please give us an example with:
- An enthalpy value of saturated steam from Hysys at a given pressure P
- An enthalpy value of saturated steam from ASTM tables at same P
- The latent heat of vaporization at P (should be the same in both sources)
Edited by sheiko, 12 March 2012 - 10:08 PM.
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
