Dear Sir
Could anyone kindly help me which vertical leaf filter vendor provide
GA drawing and pressure drop calculation formula in their
Company website? This vertical leaf filter will be used
in the pump suction side for the oligomer production plant.
Usually this type filter pressure drop around 300~500 kpa
And the life cycle for the leaf filter around 7 million time per
year, but I would like to get accurate number of physical data for this type
Filter.
Thank you very much for your kindly help and sharing.
Best Regards,
Vertical Type Leaf Filter Pressure Drop And Maintenance
Started by knapee, Mar 15 2012 09:48 AM
No replies to this topic
Posted 15 March 2012 - 09:48 AM
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
