This may well be covered elsewhere in the forums but I haven't been able to find it so feel free to point me in the correct direction if I've missed it.
I wondering how a control valve can increase the allowable pressure drop before choked conditions are met?
I've been calculating the maximum gas flow through a control valve in order to check a relief valve sizing scenario. To do this I've been using the ANSI/ISA Flow Equations for Sizing Control Valves.
In these equations x=deltaP/P1=1-(P2/P1) and x<=Fk*Xt
Typical values of Xt that I have found range from c.a. 0.3 - 0.9
If we assume we are looking at air so the heat capacity ratio,k = 1.4 then Fk=1 and x is totally dependent on Xt. If Xt =0.9 then x=0.9 and flow through the valve becomes choked at P2/P1=0.1
If I assume the gas in question is ideal I can apply to following condition at choked flow P1/P2=[ ( k + 1 ) / 2 ] k / ( k - 1 ). This suggests that P2/P1~0.5 at choked conditions.
Can anyone explain how a control valve can increase the allowable pressure drop before choked conditions are met?
Gas Phase Control Valve Pressure Drop Ratio Factor, Xt
Started by antator, Apr 02 2012 01:09 PM
control valves critcal flow xt control valve
Posted 02 April 2012 - 01:09 PM
Posted 03 April 2012 - 02:12 PM
Antator,
Refer the attachment regarding the sizing of valves by Parker. It may provide you the answer you are looking for.
Ankur
Ankur
Posted 04 April 2012 - 04:28 PM
Thanks for the reply.
I still find it curious that Xt values up to c.a. 0.9 are possible given that through an orifice I would normally expect choked flow to occur at approximately 0.5 asssuming ideal behaviour. I guess I will have to accept this for the time being.
