Hi all,
I am looking for a formula which would give the optimum pipe diameter as a function of flow rate, density, maybe viscosity etc.
The correlation for steel and stainless steel can easily be accessed, for example they are given in C&R Vol 6. However, if my tubes are made of some other material (cupronickel) is there a way i can find a correlation specifically for this material or a general correlation not depening on material?
Thanks,
Optimum Pipe Diameter
Started by stuuuuudent, Apr 13 2012 01:30 AM
Posted 13 April 2012 - 01:30 AM
Posted 13 April 2012 - 02:10 AM
student,
FLow= Velocity X Area
Dinsity=Mass/ Volume
Area =3.14Diameter square/4
Pressure X Volume= Number of moles X Gas constant X Temperature (PV=nRT)
If you know the concept of Hydraulic diameter and Reynolds Number, Kinematic, dynamic viscosity and bernoulis equation you can calculate it.
Attached some documents for your help.
Shivshankar
Shivshankar
Posted 13 April 2012 - 02:22 AM
Yeah, but I have liquids rather than gases.
The formula C&R Vol 6 gives for steel pipe is d=293 x M^0.53 x rho^-0.37 and for stainless steel d=260 x M^0.52 x rho^-0.37 where m is mass flow rate:
So I guess there should be a similar correlation for other materials, only the constant is different?
Posted 13 April 2012 - 02:31 AM
Student,
Can you attach your calculation copy ?
See this documents
Shivshankar
See this documents
Shivshankar
Posted 13 April 2012 - 02:43 AM
Yeah, Shivshankar,
From the piping and instrumentation document page 219 is the one I refering to. In the beginning there are some genral guidelines and in the end the otimum diameter for steel and stainless steel is given. Do you think I can find a similar correlation for cupronickel pipes from somewhere, thanks! I am actually using this information to design my heat exchanger, in particular for nozzle design
Posted 13 April 2012 - 03:15 AM
student,
you can refer
http://www.wlv.com/p...DataBookIII.pdf
http://www.wlv.com/p...-databooks.html
Shivshankar
you can refer
Shivshankar
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
