I have been recently employed in one of BP gas sites in Egypt and i have some questions:
Design: First of all, the amine sweetening plant is designed to treat 55 MMSCFD gas (7%mole CO2, 1,200 PPM H2S) with an amine flow rate of 258,000 lb/hr (42% MDEA; 3% Hydroxy-ethyl piperazine; 55% H2O)
Gas temperature = 115 F
Gas pressure = 158 PSI
Lean amine temperature = 130 F
Lean amine pressure = 155 psi
Currently: gas flow rate = 12 MMSCFD (4%mole CO2, 250 PPM H2S) and amine flow rate = 150,000 lb/hr (42%MDEA 3%HEP 55%H2O)
Gas temperature = 90 F
Gas pressure = 160 psi
Lean amine pressure = ???
Questions:
- I believe that the amine circulation rate should be lower than that since the gas flow rate has dropped to around 20% from design data. However, the circulation pump is a centrifugal pump with no VFD - so the pressure will be different if I lower the circulation rate. So how can i work this out?
- Sweet gas outlet temperature is 120 F, Which is kind of weird, since it's 10 F lower than lean amine temperature, Personally (From my little experience) I haven't seen the sweet gas temperature lower than the lean amine temperature before. What could be the possible cause for that?
- What is the definition of flooding factor? And how can i know/calculate it if the flow rates/pressures for lean amine and gas rate are not adequate for the amine absorber.
Edited by Art Montemayor, 17 April 2012 - 11:13 AM.
