Am currently working in an Air Separtion Unit. We are facing a strange problem here. We have two Direct Contact coolers in our Plant. The hot compressed air(135 DegC) after Air Compressor enters into the 1st Cooler having a direct heat exchange with Cooling water suppiled via Pump. This cooled air enters into the second cooler for further cooling, exchanging heat with Chilled water coming from a Water Chiller. The 2nd vessel is having a demister Pad to prevent entraiment .
But the Problem is that we are observing physcial carryover of water along with air ex 2nd Cooler. Intially, we suspected that the demister failed, so it was replaced. But still the problem persists. On adjusting water flow rate to both the Vessels,we found that the Carryover has reduced. But to our utter surprise the carry over has increased significantly since yesterday, even with this reduced flowrate.
Some have suggested that the carry over might be due to the Poor quality of water suppiled. We indeed have observed huge foaming in suppiled water.Is this the reason or there is something other, Please suggest.
The Air is then supposed to enter Dryers for Purification. Now water has also entered in these Vessels. I am fearing that it might have damaged the dessicants(Mol Sieve,Alumina).
Please help me out.
Bodhisatya.
Edited by Art Montemayor, 23 April 2012 - 10:07 AM.
