Hello ,
I work in water treatment plant ,I have problems which it is rise aluminium ratio !!
Posted 22 April 2012 - 12:43 PM
Posted 22 April 2012 - 01:06 PM
Hi there Iraqi_eng8,
Could you be more specific with your problem, and could you give me a little bit more information on the type of process you are dealing with.
Thanks,
Ricky
Thanks,
Ricky
Posted 24 April 2012 - 05:47 PM
thank you for reply
A problem is rise ratio of aluminium in the treatment water , My process is enter the raw water to large tank and added the alum and after that it's go to sedimentation and then to filtrated and then add chlorine and then pumped to the town ,
