Hello
Which is the minimun recommended velocity for the gas flowing through tubes in a Shell & Tube TEMA exchanger? Which standard shall I check?
Minimum Velocity Of Fluid Through Shell & Tube Exchanger
Started by Butterfly, Apr 26 2012 02:55 PM
Posted 26 April 2012 - 02:55 PM
Posted 26 April 2012 - 03:11 PM
My company recommends 3 ft/sec min. on shellside and 5 ft/sec min. on tubeside.
Posted 28 April 2012 - 09:17 AM
Dear Sir
Here is cooling water flow velocity in tube side aad shell side for your information.
Edited by knapee, 28 April 2012 - 09:23 AM.
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
![]() Rotated Triangular Tube Layout Vs Triangular Tube LayoutStarted by Guest_Heat Transfer Novice_* , 28 Sep 2024 |
