Hi all, I m working with Natural gas pipeline terminal.
After maintenance and re-assembly of the flanges, we do check for leak in flanges by soap water.
Is there any other method for checking leaks in flanges...?
What is the standard method of check...?
Leak Detection After Maintenance
Started by R NESAMANI, Apr 29 2012 01:56 AM
Posted 29 April 2012 - 01:56 AM
Posted 29 April 2012 - 03:20 AM
Nesamani,
Doing leak check using soap suds is a very standard way of checking for leaks in piping pressurized with air or gas.
Refer the link below on some tips related to using soap suds or soap solution:
http://www.hvacfun.c...s-equipment.htm
Also refer Section 7.6 of the the link provided below:
http://boonchoo.org/...g of Piping.pdf
A gas detector may also be used if the system is pressurized with process gas or hydrocarbon gas as per the link provided above.
Posted 04 May 2012 - 07:10 AM
Yes, leak testing is still done with soap bubbles, however you have to be sure that the soap solution is the right consistency as otherwise bubbles may not get formed (if too thick-I am not joking!). That said you can use ultrasonic devices for testing leaks as well as gas detectors (if you know what gas /vapor is being carried by the pipeline).
Posted 04 May 2012 - 10:46 AM
Detection Limit Of Protein SwabsStarted by Guest_Hartwa_* , 12 Feb 2025 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
![]() Hydrogen Storage Tank Depressurization Duration - For Maintenance!Started by Guest_panagiotis_e_* , 11 Jul 2024 |
Ethylene Tanks Cctv For Leak DetectionStarted by Guest_DarthJamming_* , 30 May 2024 |
![]() Maintenance And Power ConsumptionStarted by Guest_Lyne_* , 04 May 2024 |
