Hysys : Fluid Package For Hock Process (Cumene-Phenol Process)?
Posted 02 May 2012 - 06:56 AM
what fluid package should i use for two type of component which is cumene and phenol?
i would like to separate these two component using column distillation.
can i use either SRK or PR SV. can u tell me why,thanks!
Posted 02 May 2012 - 07:10 AM
See attache dlink for the property package selection.
Click on property wizard & follow the path. I think you will get ur reply. You can use HYSYS support also if u have user id & password.
Jatin
Posted 08 May 2012 - 02:53 AM
hi, i am just wondering,in the hysys
Try with activity coefficient model.
Posted 08 May 2012 - 03:11 AM
Posted 19 August 2013 - 06:23 AM
Dear Mohammad,
Jatin
can you plz send me hysys for this one
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
