Dear all ,
Could you please help me to solve following problem.
I want to measure Temperature in induction furnace , currently i am using R type of thermocouple for range upto 1450 degree C, which is inserted directly from top of furnace . In our process we heat furnace upto 1450 degree C and remove the thermocouple and pour the martial outside during the pouring if we not remove thermocouple then its break /damage most of the time and also if we remove thermocouple at 1450 degree C directly outside the furnace then its also damage due to the thermal shock .
So for avoiding these problems with T/C i want to go with non contact type of temperature sensors , but our furnace having large amount of fluoride fumes at 1200 degree C . so can anybody suggest me which type of non contact type sensor is suitable for this process .
With Regards
Posted 17 May 2012 - 04:29 AM
Posted 21 May 2012 - 01:00 PM
Rajpal,
Have you thought of using an optical pyrometer as a non-contact type sensor. These are considered to be quite reliable for high temperature applications.
Refer the link below for an introduction to pyrometers.
http://en.wikipedia.org/wiki/Pyrometer
Posted 21 May 2012 - 09:19 PM
Infrared pyrometers are suitable .
http://www.wintron.c.../irproducts.htm
I was using one of them to follow the degradation of insulation material in lime kiln .
Hope this helps
Hope this helps
Flowing Temperature- PsvStarted by Guest_stu_* , 17 Feb 2025 |
![]() Temperature PredictionStarted by Guest_paul_ohoir_* , 10 Jan 2025 |
Fire Relief Case - Relieving TemperatureStarted by Guest_alexzo1990_* , 06 Nov 2024 |
