Hey,
My name is Juzer and i am working on a problem of evaluating the losses effectively in a boiler.
I have come across the case of solid fuels, where indirect efficiency calculation is proving difficult.
I have a theory that in case of coal with large number of fine particles( around 30% particles of size < 2 micrometer) the draft can carry off the particles with it also they cna fall through the grate. So I am trying to apply a mass balance and element balance to find out this quantity.
Details of the mass balance:
Mfuel + Mair = Mbottomash + Mfluegases + Munburntfuel.
to get flue gas masses ill be evaluating the flow rates of flue gases using anemometer, then invoking ideal gas law to convert volume fractions to mole fractions. Also i'll assume NOx formation is negligible and unburnt solid fuel volume is negligible.
The aim is to get the unburnt solid fuel quantity
A few concerns i have:
1. Some of the solid fuel may burn along the way in the flue pipe before it reaches my flue gas analyser.
2. some of the solid fuel may fall through the grate as it is fine, but will be clubbed with bottom ash.
Could the forum please tell me about possible shortcomings of this method. Please be critical.
To crosscheck ill be using an element balance
using this equation(ignoring NOx and H2)
CxHyOz + a*(1+E.A.)O2 ----> bCo2 + cCO + dH2O + eO2 + fC
then applying elembent balance
y= 2d
z+2a(1+EA) = 2b +c +d + 2e
here d is known
and b:c:e is known. Hence we can get result
only problem is i dont know how from ultimate analysis (without molecular mass) i can get formula
then ill apply carbon balance to get unburnt carbon
x = b + c +f
Thanks for Reading
Juzer
Method To Evaluate Quantity Of Unburnt Fuel In Solid Fired Boilers
Started by juzer, May 31 2012 05:37 AM
boiler losses unburnts
No replies to this topic
Posted 31 May 2012 - 05:37 AM
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
How To Have 2 Property Method In Aspen Plus Based On Phase?Started by Guest_m.ghaziasgar_* , 21 Aug 2024 |
