Hi, good day to everyone.
I'm a new engineer assign to our powerplant and I have inqueries regarding the caustic corrosion in boiler systems.
According to various sources, there are three conditions that must exist in order for caustic corrosion to occur.
1. Free caustic in the water
2. Specific condition of stress
3. Mechanism for concentration
My question is regarding the 1st condition. Can sodium ion (Na+), present to the boiler feed water system, possibly cause caustic corrosion?
Given that the boiler feed water pH is around 8-9, will the sodium ion react with the hydroxide ions in the water to form caustic and ultimately cause corrosion?
For the third condition, is the concentration mechanism applicable only to free caustic in the water or does it also apply to sodium ions?
Thank you in advance and best regards.
Caustic Corrosion/ Caustic Cracking In Boilers
Started by Cwsrt, Jun 17 2012 08:09 PM
caustic corrosion cracking stress sodium hydroxide concentration boiler steam generator
No replies to this topic
Posted 17 June 2012 - 08:09 PM
Bulk Residence Time In Naphtha CrackingStarted by Guest_mehul_* , 19 Oct 2018 |
Caustic Tower - Acid Gas ScrubbingStarted by Guest_rachalex4_* , 05 Dec 2022 |
Caustic Tower In One Dual Feed Cracker UnitStarted by Guest_VIrendra20911_* , 03 Nov 2022 |
Monitoring Of Level Control In Steam BoilersStarted by Guest_Movers_* , 14 Sep 2022 |
Deaerator Equipment In BoilersStarted by Guest_CHEMSTRONG_* , 07 Aug 2022 |
